had my - termainal unplugged for 14 hours... ecu is
still holding my codes... i thought i can get rid of
them that way?????
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
http://personals.yahoo.com
Monitoring Service trial
http://us.click.yahoo.com/Gi0tnD/bQ8CAA ... /XoTolB/TM
ecu reset CEL
Josh Colombo
ecu reset CEL
When you say terminals, do you mean battery terminals? or the little black plug terminals. You want to disconnect the negative battery terminal for about an hour or so, and then follow the procedure I described earlier. Then check the codes. If you have done this, and still get the same codes, then those sensors are probably bad.
-----Original Message-----
Sent: Thu 10/25/2001 7:49 AM
Cc:
Subject: [BC-BFLegacyWorks] ecu reset CEL
them that way?????
Do You Yahoo!?
Cc:
them that way?????
Do You Yahoo!?
Nissan-Subaru
ecu reset CEL
yup battery terminal
ordered the o2 sensor today....
> negative battery
> the procedure I
> have done this, and
> probably bad.
> Josh
> From: Nissan-Subaru
> Cc:
> of
> them that way?????
> Do You Yahoo!?
> email to:
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> ATTACHMENT part 2 application/ms-tnef
name=winmail.dat
Do You Yahoo!?
> negative battery
> the procedure I
> have done this, and
> probably bad.
> Josh
> From: Nissan-Subaru
> Cc:
> of
> them that way?????
> Do You Yahoo!?
> email to:
name=winmail.dat
Do You Yahoo!?
