My 90 originally had air suspension. I have already removed the struts and the compressor/tank but I'm thinking there are more parts to remove for slight weight savings. I assume the complete system consists of -
4 struts in the obvious location with special plastic covers
Pump and air tank in drivers fender "under" battery"
Dash height switch
Wiring? (is it a separate harness or somehow integrated?)
Computer?
Air Suspension parts locations
The air suspension computer is under the driver's seat. The wiring is probably be part of the car harness, so I don't think you'll be able to do anything with that.
Nope, abs computer is under the passenger seat.
I've put scans from the factory manual on my site which tells where all the electrical control units are...along with relays, etc
http://www.surrealmirage.com/subaru/swa ... l#location
