edm headlight aiming issues (pictures)
theflystyle
Post by theflystyle »
i got a pair of edm's from ben earlier and they looked great, just recently fixed the gap issue with the corners and took some pics.. since ive been using the parents garage and have finally used my headlights at night ive come to find the aiming sems to be really off. i took pics of what i am talking about, but i cant post them till i get back home. until then im hoping someone might have an idea.
the rear of the edm's, heres a picture from bens ad where he is selling them. rear of headlight
the top left white adjuster aparently adjusts the horizontal and the screw on the back of the electric motor adjusts the vertical. the horizontal when i turn the screw does move, but when i try to adjust the height of the beam nothing happens. the screw just turns and turns and the little knob right below the screw can be seen rotating.
i took a test drive on a local road (boonies) and the beam is shooting way up and to the right. as i said i will get the pictures up that i took shining onto the garage door, but until then anyone have any advice??
thanks
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
Aerotech
Post by Aerotech »
How far did you try turning the adjuster? Maybe try it with a power screwdriver?
Check that your lower mount points are all the way in.
Are both headlights doing this? The electric levelers are really designed to lower the light beams to compensate for heavy trunk loads, not raise them to light up the roof...
Jerry
theflystyle
yeah i used a power screwdriver and nothing happened. i have not an idea.
i want to wire the adjusters but i dont want to cut the wires, im trying to get a harness together. i wonder when they were removed from the car what setting they were left at
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
theflystyle
pics
now here are some pictures of what im talking about.. taken from 25 feet away
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
jefferson
Post by jefferson »
I had to take my adjusters off the lights and found that the gear was not turning with the shaft. Corrosion and plastic deterioration had taken their toll. The gear would turn fine as long as no load was placed on it, but the minute even the slightest load was applied it stopped. I used jb weld to make the gear do it's job. You will need to clean the shaft up real good and be very careful with the jb weld as you only want to attach the gear to the shaft and nothing else. It doesn't take much.
Jeff
jefferson
Post by jefferson »
I reread your post and the adjusters I had problems with was the horizontal if I remember right. The ones off the electric adjusters were fine. Still wouldn't hurt to remove them and see what is up.
Jeff
Aerotech
Post by Aerotech »
It looks like it's only the left side thats REALLY out of whack, the right side is about where it should be...
If you're unable to get it close to where it's supposed to be, start investigating the sheetmetal for previous collision damage. Your old headlights may have been compensating for something bent.
Jerry
theflystyle
even if the little plastic knob turns when i turn the screw on the electric motor, could that still mean the gears are not moving?
also, i noticed on the headlamp there is a peice that is on the passenger headlight that is not on the driver side. its at the top of the headlight, on the inside and looks to be a shield. i have a picture i will upload later, i wonder if that has anything to do with it.
thanks again for everyones help. i really appreciate it
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
legacy4ever
Post by legacy4ever »
Hey Ali sorry to hear that the headlight doesn't work right :(
Did you check if the inside reflector is attached to the left lower shaft? There is a ball joint and sometimes it happens the reflector comes off that connection. Just take the bulb out and try to pull the lower part of the reflector towards the engine. If you feel/hear a click it jumps in its place.
I'm curious, both headlights are identical and definitely there's no shield. Please post the picture.
Ben
93MY EUDM Legacy EJ22
theflystyle
i took out the bulb and was able to freely move the reflector, but didnt see or get how it can click back in.
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
Oh yes.....I've experienced everything you guys have posted ;) It brings back horrible memories.
The damn reflector likes popping off the adjuster ball. What I did was take a wooden dowel and wrap a towel around it with rubber bands. This gave me a little more leverage to pry/pop the reflector back on.
Regarding the aiming.....the electric gears get messed up and crack. Luckily, I had some spares motors, and swapped stuff around so the gears worked.
The JB Weld method sounds pretty good. It wouldn't hurt taking the motors off and cleaning everything up and regreasing things.
theflystyle
i am having a hard time understanding what you guys mean... all i seem to be doing is just bouncing the reflector around. i dont see how the reflector pops back in
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
Pull the electric leveler motor off and you'll see what we mean. There's three screws holding it to the headlamp case.
theflystyle
i got the pass side to pop in pretty easy, it doesnt move up and down freely anymore... the driver side is being a bit more stubborn.. guess i will have to remove the motor on that one..
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
theflystyle
re
just wanted to give an update so this may help out someone if it ever occurs to them..
here is the picture of the motor removed from the back of the headlamp with the long silver control arm shown with the ball joint at one end...
here is the picture of the ball joint in the reflector housing inside the headlamp. when the screw on the motor turns one way or another it moves the adjuster arm in or out, which caused it to pop out and not aim correctly. it still pops out when its pulled in to far but i found the equalibrium between the two.
i still have to fine tune the aiming but it is way sharper, brigher and more defined then the usdm. i def recommend them
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
farfrumwork
Post by farfrumwork »
Just be carefull when using a power drill/screwdriver for adjusting these.
I cracked one of the motor housings when using my drill. If it goes to the end of the adjustment range it places load on the housing. I fixed it with JB weld (what Can't it do!?!?!?!?! haha) and they are adjusted well. I don't use, and never plan to use, the electric levelers (although they ARE cool).
just a cautionary tale....
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
