Moderators: Helpinators , Moderators
d_timmons
Posts: 4 Joined: Fri Jun 27, 2008 2:10 am
Post
by d_timmons » Fri Jun 27, 2008 2:14 am
why does my 94 legacy awd hit the rev limiter at 4200 before it even shifts. its really annoys me. please help
Ej22TIM
Posts: 137 Joined: Mon Sep 25, 2006 4:50 am
Post
by Ej22TIM » Fri Jun 27, 2008 2:25 am
sounds like its starving for fuel, replace the fuel filter and run some injector cleaner through us and let us know what happens.
Tim
93 Legacy SS Winestone 5mt swapped
Megan Racing Bellmouth 13psi
WRX Intercooler and Hoodscoop
JDM ej20G DOHC head swap, wiseco pistons and td04 in the making.
d_timmons
Post
by d_timmons » Sat Jun 28, 2008 5:18 pm
its notstarving for fuel its hitting te rev limitelike some one was messing with the computr but no one has
Posts: 3242 Joined: Mon Oct 16, 2006 9:44 pm
Post
by ericem » Sun Jun 29, 2008 5:31 am
Maybe there is a issue with the TPS ( throttle position sensor). Can you still hit redline if you floor it aka 6500rpms?
d_timmons
Post
by d_timmons » Mon Jun 30, 2008 3:36 am
it can still rev past that if i am in park or neutral. but here is the weird part i put in a new cd player and it let me red line in drive today, so i think it is a short somewhere. now my parking lights and dash lights wont turn on either, the guy who had it before me butchered the wiring harness for the radio so i dont know what is all screwed up. i guess it is good luck to me.
Posts: 3526 Joined: Wed Jul 18, 2007 5:07 pm
Post
by SubaruNation » Mon Jun 30, 2008 5:56 am
i'd hunt that person down first,
is your IAC hose connected to your bypass valve ok?
maybe change your 02 sensor...
or speedo is busted?
Zach - Legacy
Franken sti n
93forestpearl wrote: Keep up the good work. You'll never know what you are capable of unless you push yourself.
d_timmons
Post
by d_timmons » Mon Jun 30, 2008 3:09 pm
it has a new o2 sensor. the speedo is off a couple mile an hour but that shouldn't affect the shift. and what is a iac hose
Posts: 3043 Joined: Tue Jan 25, 2005 9:14 pm
Post
by 93forestpearl » Mon Jun 30, 2008 5:02 pm
The ECU gets its speedo signal from the spedometer itself, since its opereted by a cable. The "reed switch" is what sends the signal.
Maybe that got chopped somehow?
Post
by SubaruNation » Mon Jun 30, 2008 8:17 pm
it connects to your large black "charge pipe"
that goes from your throttle body to your turbo intake outlet.
the bpv is underneath that
Zach - Legacy
Franken sti n
