ok i am posting this here hoping some one knows the answer to this question. I have a 1993 Impreza with dohc jdm heads on a special block. They came off of a high compression ej20 i have no idea what it's letter designation is, only that it is definitely an ej20, any way. I have phenolic timing gears on it and, it is n/a so i am still running the stock ej18 ecu. the car wont start after the swap, does any one have any pointers as to what i should look at first, i just got the motor in the car yesterday and tried to start it at 10:30 at night, it wouldn't start so i called it a night. i did absolutely no trouble shooting what so ever. any one have any tips or suggestions as to where to start? any insights as to electrical stuff i need to change would be welcome as well.
thanks
jeff
help... sohc-dohc question
92 SVX LSL tour- 5spd swap baby
92 turbo touring wagon now also 5-speed swapped
89 xt6 stock
[quote="danetrain"]Fuck wyoming[/quote]
89 xt6 stock
douglas vincent
GodSquadMandrake
Legacy Rally Guy
Well, you can check the compression, but if the cam gears are made for a different sensor.. that'd certainly make the car not start..
but if you've very low compression in one cyl, low compression in 2 cyls or 3 cyls and high comp in one.. your cam(s) may be out of time..
Caboobaroo
