Hello,
I have found a rare aluminium deposit under the rear right speaker in
my 94´ touring wagon, what is the purpose of this one?,it has not
filler hole (sealed at least the upper side), its capacity is around
2 liters but of what? This is not the washerwiper fluid because it is
located at the rear left corner of the car. Does any one have the
same thing in your car? I can´t see if it has some connection because
the whole thing is covered by the plastics panels.
Any opinion will be great!
Christian
strange deposit?
melrod@optusnet.com.au
strange deposit?
Christian,
what you have found is the 'fuel seperator'. Is connected to your
fuel tank.
cheers, Rod
--- In BC-BFLegacyWorks@y..., firetire@h... wrote:
> Hello,
in
around
is
because
> Christian
Universal Inkjet Refill Kit $29.95
Refill any ink cartridge for less!
Includes black and color ink.
http://us.click.yahoo.com/bAmslD/MkNDAA ... /XoTolB/TM
fuel tank.
cheers, Rod
> Hello,
in
around
is
because
> Christian
georgerbyrne@yahoo.com
strange deposit?
Yeah that is the fuel vapour separator.
They only come in the AWD models.
It is there in relation to the hump in the tank, not totally sure
why!
I had to install one in my FWD when converting to AWD, it doesn't
have any pumps or anything, it's just a plastic tank inside an
aluminium casing, with three pipes running between it and the fuel
tank.
Sorta Weird really! Could be an expansion tanky thingy!
George Aus.
--- In BC-BFLegacyWorks@y..., melrod@o... wrote:
> Christian,
> fuel tank.
> cheers, Rod
> > Hello,
speaker
> in
> around
it
> is
> because
> > Christian
http://us.click.yahoo.com/XwUZwC/MkNDAA ... /XoTolB/TM
why!
tank.
George Aus.
> Christian,
> fuel tank.
> cheers, Rod
> > Hello,
speaker
> in
> around
it
> is
> because
> > Christian
