i have had a slanted V2 TMIC in my garage for about a year now and will finally have the extra cash AND time to get the damn thing in there.
any tips?
do i need to make a mounting bracket for it or do the hoses keep it in place? in its last installation before i bought it the mounting brackets were cut off of it.
do i need to move the coolant res. for this to fit?
is the clutch fluid cyl. in the way for this one?
thanks in advance,
greg
installation ?s regarding a V2 TMIC
greg donovan
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
Not sure if it will help but here is a pic of a V2 TMIC on a swapped SS - PM Aerotech to find out how everything fits.
http://bbs.legacycentral.org/viewtopic. ... c&start=50
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
greg donovan
yeah i have eyballed lots of pics but they dont really tell me much and it seems that many people that own the cars with them on it arent the ones who put it on.
is the throttle body farther over towards the drivers side on aerotech's car?
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
uh... slanty IC's are a "unhappy woman" to install.
if i can remember right, you have to shave (cut) down our stock throttle bodies and hammer the firewall (which is kinda fun) and relocate the coolant tank... and i dont know how the Y goes on it but you will have to fab something up from there too..
just do an 06 wrx one
ultrasonic
I don't think the TB needs any mods. That's for a 2002-ish WRX intercooler, I believe.SubaruNation wrote:uh... slanty IC's are a "unhappy woman" to install.
I'm collecting parts for a slant i/c install, too. Here's what comes to mind:
- relocate the igniter
- relocate the coolant tank. I think turning it 90 degrees is enough.
- remove one bracket from the i/c to clear the coolant tank? May not be necessary.
- clutch reservoir may be in the way on some cars. this can be solved by a later offset reservoir that is a direct fit.
- AC line may need to be forcibly adjusted (bent), only on some cars.
- move some hoses and/or harness to under the pitch stop.
- coupler to TB and inlet hoses are generally enough so that mounting brackets are not required.
That's just from memory, but I think that's the main issues.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
dscoobydoo
I went the route of the slanty awhile ago.
Ultrasonic is correct in the mods that have to be performed.
Sadly, the slanty is not very big and it seemed to me that the air through the small hood scoop was not directed very well for this intercooler.
You will have to do the same mods for an 06+ wrx intercooler and it sits right underneath the scoop- being a better fit as far as usefulness.
But if anyone wants one, I do have an original WRX-slanty diversion plate for under the scoop.
You can try and make it fit.
I gave up and went to the 06 IC
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
greg donovan
yeah, i bought this about 18 months ago, just before the 06 and up TMIC starts showing up for cheap. i think i may get one of them instead too.dscoobydoo wrote:I went the route of the slanty awhile ago.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
greg donovan
took another look at this today.
it appears that the way the tanks are designed the clutch res would not need to be modded.
the coolant expansion tank does need to be moved. mine is broken and fixled with a 2 dollar fix that hs lasted for nearly 2 years so maybe it is time to get a metal WRX tank now and move it over to where the now defunct ABS unit sits.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
