ok, i have a problem
i have a NA block n heads w/ 22t crank/rods/ and pistons
i have stock wrx turbo and im trying to find a good place to tap for oil..
theres a plug on the back side of one of the heads for oil, but i cant find adapters or anyone that makes fittings for the block to the turbo... any ideas?
where did the ej22t oil feed tap from?
turbo oil lines
The stock oil port for the 22T heads is an M12x1.25. I'm not sure what that port is, but you could use the plug you took out to figure out the thread size. Then a AN adapter fitting like I did.
www.anplumbing.com has a bunch of different metric to AN adapters. I used a M12x1.25 to -4.
thx for the site, placed my order.... umm i have the feed adapter that came with my turbo (stock wrx) - is the male infeed fitting a -4?93forestpearl wrote:The stock oil port for the 22T heads is an M12x1.25. I'm not sure what that port is, but you could use the plug you took out to figure out the thread size. Then a AN adapter fitting like I did.
