.040 Over bore too much?
For my 2.35 I have to use .020 over bore pistons, thus I have to have it bored...
Now what I was thinking, why not go with .040 over bore and make the engine a 2.4L closed deck.
What do you guys think?
Re: .040 Over bore too much?
smh0101 wrote:For my 2.35 I have to use .020 over bore pistons, thus I have to have it bored...
Sounds good to me except I believe Subaru factory says to not overbore beyond 0.020 inches. They're being conservative, of course. Also, check with your piston supplier and make sure they offer an oversize of 0.04...... I don't think all of them do. At 0.04 overbore I would definitely go with molybdenum coated skirts to reduce heat/stress as much as possible on the cylinder bores. It should be fine then.......... at least that's the theory.
What's your final setup going to be ?
EJ22 n/a installed in 1984 Volkswagen Transporter/Vanagon/Bulli
EJ22 motor with blown head-gasket undergoing rebuild to stock specifications
Wiseco, they make them for this build.
And its gonna be:
22t block
2.5L Phase 1 Crank/Rods
RS 2.5L DOHC NA Heads
vf39 or td05-16g
ej20g intake manifold
stock new subaru bearings
wiseco pistons
sti 565cc injectors
And its gonna be:
22t block
vf39 or td05-16g
wiseco pistons
sti 565cc injectors
You could probably get away with it...but .040 is a big cut...and will pretty much render your block useless for future boring. Keep in mind that it is really double the necessary clean-up bore...which is why Wiseco makes those pistons in .020.
Have you done the math to find that twenty thousandths more per hole will actually increase the displacement by 1/20th of a liter?!?
Nick beat me to it.
You will never notice (seat of pants) that extra displacement.
Being able to clean up the block again should you have a meltdown is far more valuable.
If your looking for a DynoQueen, by all means bore it out.
haha, no. I want drivability, screw dynos!
Mmkay, sticking with .020!
I was in the same boat. I chose the .020 overbore for the fact that I can always take it out a little more if the need arised. Its not worth the .04 liters. Plain and simple.
If you want to get serious like that send your block to Darton. They'll hook you up with a 2.65L. Or Ron at what used to be Axis.
