weird noise been going on for a while
the_watts10
Post by the_watts10 »
so for a while ive had the really hard knock near the tranny when i turn my wheel and drive either forwards or in reverse sounds like and popping axle but ten times louder almost like someones ramming into the back of my car
thoughts?
center diff maybe?
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
Check the driveshaft for a busted U-joint.
the_watts10
what type of legacy u joints will fit my car
(94 SS)
ciper
Post by ciper »
Is it an automatic? If so I vote torque bind.
the_watts10
yes its automatic
The automatic having problems is more likely. You can visually inspect the driveshaft joints next time you're under the car.
Search for "4EAT torque bind"
