Aerotech wrote:
Open in Paint...You have to use the select square, as tight to the tire as you can get it, then copy. Open the car image, and paste, then reposition. Do this 4 times. You'll have to touch up the wheel wells where the white square intrudes on the original image.
This should be pretty close to the correct size.
ya i did that.. you dont want to know what they looked like after
i'm probably gonna make one in my color with my rims in a few days. i didnt have glue so i used tape, and even though i was really really careful it didnt some out as perfect as i wanted. hopefully it will turn out better with glue
