Driving like a 95 year old has it's rewards
James614
Post by James614 »
Just measured 22mpg in my Touring Wagon today on 5/8ths of a tank. The best I ever got previously was 19.2 and I usually get a solid 18.4 - 18.8. Had to stay under 2000rpm 99.999% of the time to achieve this :shock: Not quite the payoff I was hoping for considering that our HHR at work went from 28mpg to 35mpg with similar methods.
Whoever came up with that "6cyl power with 4cyl economy" for turbo fours should be shot in several non-fatal places.
douglas vincent
Post by douglas vincent »
Replace O2 if you havenet in a while
douglas vincent
with OEM!!!!
Murphy
Post by Murphy »
i got 28mpg on my last fill up at 1/8th tank, which is driving normally, if i had an SS i dont think i would have the amount of will power it takes to keep it under boost
...thats why i want to go diesel :twisted:
1990 Legacy LS, 4EAT
Aerotech
Post by Aerotech »
Yeah, but you'll end up going turbodiesel, putting in intercoolers, water injection, boosting to 25psi... once you go turbo, it's impossible to live without it, and equally impossible to avoid tweaking the motor for more power. I'm going diesel with the Syncro, and it's happening as we speak. Parts are in the mail :twisted:
Jerry
Fkyx
Post by Fkyx »
I turned my boost down last week. It almost makes me cry when I get on the gas. :( At least it still scares little children.
James614
Post by James614 »
Murphy wrote: i dont think i would have the amount of will power it takes to keep it under boost
Took me almost year with my TW to finally stay out of it between just 1 fillup. Right now its a damn good thing I can't afford an intercooler, cause I have a MBC sitting on my desk and I know things are going waaaaay south once that snowball starts rolling.
Post by SubaruNation »
i average 26 with my tw...
weird. :?
ya just stay out of it and go 65 on the highway and you get good MPG
Ya, it sounds like you're due for a tune-up. Try plugs (oem or equivilant), wires, and pcv if you haven't recently.
I average ~25 in my turboswapped legacy wagon, and traffic (people) piss me off most of the time.
James614
Post by James614 »
I'm starting to wonder about differences in our fuel economy calculations.... EPA for the TW is only 18/23. And the EPA ratings are reduced 15%/10%, respectively, from the actual results. So I find it hard to believe that me achieve within 99% of them in real-world driving is so far below what I should be getting...
DLC
Post by DLC »
At 4500ft, my GT got me just shy of 28MPG over the course of 360 miles (16 gallon tank), with about half of that highway (55-65mph) and city (25-55) and NO AC (crack the windows).
I think altitude helps me, because if there's less air and no forced induction, I have less potential power, so less fuel will be used by default.
Still thinking about something 35MPG+ though.
Legacy Central
DLC wrote:At 4500ft, my GT got me just shy of 28MPG over the course of 360 miles (16 gallon tank), with about half of that highway (55-65mph) and city (25-55) and NO AC (crack the windows).
get a...
Murphy
Post by Murphy »
if you drive 1000 miles a month at 28mpg
thats around 35gallons a month which is around $140 a month which is about $1700 a year
the Tesla Roadster cost $109,000 so in order to get your moneys worth you would have to make it last 64 years before you ever saved a penny on fuel
ya, you're point?
SubaruNation wrote:ya, you're point?
Keep the Subaru!!!!!!!! :roll:
86ruguy
Post by 86ruguy »
well, before i screwed up my car(btw...not sure it was my fault) i was getting about 20.5mpg driving 26 miles one way to work with 50% of that time spent idling because of traffic. plus all of the round town driving i was doing in the time i was not at work. i was going thru about 7 tanks a month. 15x4.20=$63.00x7=$441.00 a month in gas
since my car broke 3 weeks ago, i have spent $37.50 on the bus and train getting back and forth to work.
$37.50x3=$112.50
so even when you add in the gas i have to put in my wife's car, i still come out ahead on fuel costs. BUT BOY DO I MISS MY FRIGGIN CAR!!!!!!!
92wagon (wife's)
92 sedan (sold)
91 ss no mods (sold)
88 GL Wagon (broken)
lol i know i was kidding ;)
scuzzy
Post by scuzzy »
well I drove 220 miles Friday night and burned through most of a tank of fuel (10.8 gallons I think the total damage was)
I set the cruise at 90 (it was 11PM) and let the car take me home. I filled up the next day and my mileage came out to 20.6 or something like that.
Cruise kept the boost just under 0vac most of the way; was turning 4000-4100 rpms - I'd only go into boost on the steeper hills and usually it was no more than about 3-4 PSI; sometimes I hit 6 or 7 but not often.
#82 M4 TRSCCA Rallycross
im starting to think that staying out of boost isn't worth it.
i've used a tank and stayed out of boost most of the time (alot) and never gone over 70 on the highway.
i ended up with only ~240 miles on the tank.
but i did fill it up before i actually hit the low tank warning.
so i guess i could have made it to like ~270
Post by SILINC3R »
i get about 30 mpg driving to work and around town. if i was to go on a trip i am sure i could get around 40.
Murphy
Post by Murphy »
40? i think that is stretching it quite a bit
douglas vincent
Remember, smaller tires will give you inflated MPG numbers cause they turn more, causing you to "travel" farther distances.....
I have changed to running 89 octane (plus) versus 87 and it really seems to help, like 3-4 mph better, which easily pays for the gas price difference!
NuclearBacon
Post by NuclearBacon »
With my 5mt Swap, freeway miles, i can get a consistant 26mpg... If i'm driving a 300 mile trip on the freeway and i'm cruising at 65 to 70 mph, i've gotten 28mpg before!
That was neat :)
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
douglas vincent wrote:Remember, smaller tires will give you inflated MPG numbers cause they turn more, causing you to "travel" farther distances.....
Does that tell you that your knock sensor is bad maybe?? European cars didn't have knock sensor's but just ran high octane.
The opposite if anything - it could be pulling the timing back on the lower octane or advancing it on the higher, depending on if the turbo 87 recommended. If the knock sensor didn't work the ECU is supposed to know and it's supposed to put it in safe mode (although mine didn't do that) and not care what the octane is.
