Thread size for bracket to hub attachment?
skid542
Post by skid542 »
I've been replacing the struts in the OBW this weekend and hit a small snag in putting everything back together. I had to take the brake bracket off to get to one of the hub/strut bolts and in the process of putting it back I've managed to muck up a few of the threads - I know, go ahead and say it.....
I believe I can still save it by running a tap down through it and a die over the bolt.
So, does anyone know what size/pitch the bolt is that connects the bracket to the hub?
Thanks in advance.
FWIW, only 1 out 4 of the old struts would still rebound and 2/4 will fall down under the weight of the piston itself :).
Lee
