hi, my name is Andrew steele, welcome to my creation of my car. from the beginning is where i will start.
i bought this car back in October 2006 for $1500, with 133560 on the clock and automatic.
then after driving it for about a month and a half i blew the tranny. so it sat for 1 week at my friends house.
so i decided to do the conversion. perfect timing.
Last edited by 92ss satinsvoice on Sat Dec 20, 2008 11:48 pm, edited 3 times in total.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Um... Andy.... that car in the pic... is a nice car... but a relic of the past.
so i used a n/a 5sp set up from a junk yard for all was $318. tranny, clutch, peddles, clutch line, drive shaft and rear diff.
so far its lasted me nicely. next i installed a boost gauge and boost controller. plus a getto intake me and davey made up.
then i built a frount mount intercooler.
Andy
94 L n/a 5spd, Rip
Andy
94 L n/a 5spd, Rip
i also repainted the rear wing because the paint was gone.
Last edited by 92ss satinsvoice on Fri May 23, 2008 4:45 am, edited 1 time in total.
Andy
94 L n/a 5spd, Rip
Wow that is a HUGE FMIC! The turbo went out today, so I bet you will see mid-next-week. Let me know when you get in and I'm glad it is going in such a nice car!
Subarus are probably the most reliable cars made – they make Hondas look like South American dictatorships." - Jeremy Clarkson
i also thought that the frontmount didnt show enough so..
the beast and my brothers 2.5rs
after a little while i realised that i needed an exhaust system. so i bought an invidia cat back with an Avo down pipe.
Rallitek was having a sale on a set of rims that i liked alot so i jumped for them.
the car was getting too fast for the stock suspention. so i bought a set of 02 wrx H&R coilovers and tires for the rims.
Last edited by 92ss satinsvoice on Fri Jul 11, 2008 1:16 am, edited 2 times in total.
Andy
94 L n/a 5spd, Rip
it looked very nice and aggressive. i felt that the car needed a little more power for the show. so i installed a jdm td05 16g turbo.
i still need to paint the pipe but ill get around to it.
Andy
94 L n/a 5spd, Rip
well, i kinda put my motor out of commission for the time being.
oil rings are shot is what im guessing because the oil fill tube is spitting oil out and other then that the driver side head gasket is going cause its steaming when running.
but not to worry she'll be back shortly... with more power..
Andy
94 L n/a 5spd, Rip
here is the rebuild kit with a AEM wideband gauge and my 20g heads that just got hot tanked.
Andy
94 L n/a 5spd, Rip
i have H&R coilovers on the car, running 225/45ZR17's. and no scrubing at full left or right. im going to get bigger tires after these ones wear down. mayby 235's or 245's
Andy
94 L n/a 5spd, Rip
i'm running 18 x 48 offset
i did rub on wrx struts and springs
and even a little on the kyb's
but only at the back with rear passengers... never had a problem up front.
i was so worried about the rust, that if i rolled it, i'd end up loosing my arches!
I ended up cutting the inner lip off
the wheel gap is nasty, i want to lower it... but i'm afraid it'll be a waste of money.
someone is selling a set of eibach pro springs for my current suspension...
i'm wondering what else i'd need to do in terms of endlinks and whatnot to keep it flat in the back.
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
