94 legacy Turbo, Canada
ya, nice job man, I feel good about where that ABM went
I remeber seeing it on Buysell, i called as soon as i saw it and left messages but he never got back to me. now I know why!!!
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
I'm sorry I have to tell you this, but you're probably going to have to pull your motor again based on those pictures.
The clutch fork must be installed prior to putting the motor in, and must be installed with the throw out bearing on the transmission snout. When the engine and transmission are mated, the throw out bearing snaps into the pressure plate and all is well.
I hope the pictures aren't telling the whole store and things are installed properly, but I thought I'd give you a heads up.
The clutch fork is connected, I even got in the car after everthing was done and pumped the clutch a few times and it felt good, Except for putting the throw out bearing on the for we snapped it into the pressure plate and lined everything up as it went in, tightened everything up, and tested it all is well.
Good to hear.
I made the mistake of trying to get the clutch fork onto the throw out bearing with the engine in. Which is I why I brought it up
did you paint the pressureplate thing blue or did it come like that?
it's pretty hcore to fancy up something that will nevar evar be seen, evar
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Pictures dont tell half the story...
I just changed the fuel filter today, I see why are gauges are so far off now, half the fucking tank is in the lines!
Hooked up TB
Didnt get alternater or power steering done because i couldnt find the mounts, and i left the starter for now as i need the room for other things as of right now, but due to money restrictions this will take another month atleast to complete
Hooked up TB
Okay finally an update, Havent got much done though... Enjoy, The piping fits better than it looks!
Butchered Bumber beam painted for the hell of it
I only have the turbo side on right now because im having trouble with the other side..
Dosent it look mean?
This is my coolant Tap for the turbo, Most Stainless steel clamps per inch FTW!!
FastRust
lol, i'm thoroughly enjoying watching this...
Think i've killed the clutch in mine (or at least terrified of driving it because it'll break down on my 140km drive somewhere)... can't afford time or money to get it fixed right now... so i'm living vicariously.
carry on!
by the way, what's giving you grief on the other side?
carry on!
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
