I'm installing the AWIC and I need to know what you guys do when it comes to replacing the aluminum pipe that goes from the air conditioning beneath the intercooler? I know you would have to put a straight piece in there because the bent one with the filter in the middle is in the way of the installation. What do you guys use in place of that?
Thanks as usual,
Andrew
AWIC question....
drewriviera
I actually used the n/a a/c line. It does not have that bend in there.
drewriviera
I mention it in the thread I started for my swap
http://bbs.legacycentral.org/viewtopic.php?t=27600
but haven't done an official write-up yet.
Yeah I figured since the downpipe is ceramic coated it wouldn't be as bad.
i'd be hesitant to do it with the stock downpipe especially with the cat there.
drewriviera
0.9 bar about 13 psi, same as the car radiator.
