what is the N/A route?
bigger engine, bigger internals
I suggest you search for a thread by Matt Monson. He has done some wicked things for an n/a engine.
However without spending some money I wouldn't expect much. Even with money...don't expect much more then 200....at the most.
yea i dont want more than 200 hp since it is only fwd and i know it is going to cost money
Matt Monson
- quasi-mod-o
Ej25 block
Delta cams
EL headers and full exhaust
CAI
We call it the "high compression frankenstein". It will put you around 190chp, maybe a little bit more. Without headwork, or different heads, you won't see any more than that. There's just not enough flow to the stock heads.
Delta cams
CAI
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
