fuse that is on when car is off
Post by SILINC3R »
i bought a control modual that lets me put up to four channels on it and is hooked up to a remote. this way i dont have to use switches. i want to be able to turn my ACC lights on and off when the car is off. you no when you cant find your car or something but i cant find a fuse in the fuse relay box that is all ways hot or the power wire that goes to it
You probably won't. You'll need to run a line from the battery or tap into the ignition leads. I'd recommend on putting an inline fuse in that wire.
Post by SILINC3R »
sorry found it. took a tester to the fuse box and i am using the door fuse and it works. got fog, driving, and neons all hooked up to a remote
Arctic Assassian
Post by Arctic Assassian »
The door fuse? For the door switch? sweet!
Kickin' it old-school.
Post by SILINC3R »
Arctic Assassian wrote:The door fuse? For the door switch? sweet!
yep
