Moderators: Helpinators , Moderators
BSOD2600
Posts: 1636 Joined: Tue Sep 12, 2006 6:49 am
Post
by BSOD2600 » Sat Aug 09, 2008 6:07 am
Installed a 3" exhaust today, so had a look at the VF11 internals. The shaft didn't seem to have any play when I spun it. The white residue normal?
Same question for the O2 sensor, white normal?
BSOD2600 on Sat May 07, 2016 5:09 am, edited 1 time in total.
'11 WRX Limited
'94 TW | R.I.P.
94SS_Canada
Posts: 851 Joined: Mon May 12, 2008 4:19 am
Post
by 94SS_Canada » Sat Aug 09, 2008 6:10 am
Ive never noticed That before, I guess if you live on the East Coast that would be normal. As The salt in the sir would build up, Dosent look like something to worry about
FastRust
BSOD2600
Post
by BSOD2600 » Sat Aug 09, 2008 6:29 am
I'm west coast dude...
'11 WRX Limited
'94 TW | R.I.P.
Posts: 3335 Joined: Wed Feb 16, 2005 9:40 pm
Post
by 555BCTurbo » Sat Aug 09, 2008 5:31 pm
I've seen it on pretty much every turbo Legacy I've worked on (which is a lot)...
No worries...just the stuff getting mega hot...that's all
Posts: 3526 Joined: Wed Jul 18, 2007 5:07 pm
Post
by SubaruNation » Sun Aug 10, 2008 2:34 am
ya replace that 02, its done with
Zach - Legacy
Franken sti n
93forestpearl wrote: Keep up the good work. You'll never know what you are capable of unless you push yourself.
Posts: 27926 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Sun Aug 10, 2008 8:39 pm
Both the turbo & O2 sensor look normal.
You can't tell that the O2 sensor is toast by looking at it.
BXSS
Posts: 1301 Joined: Wed Jan 10, 2007 4:23 pm
Post
by BXSS » Sun Aug 10, 2008 11:54 pm
I'd say the car is running lean.
My turbo came off the car with a light brown color & the EGTs were about 1400* on longish pulls (0-110+MPH).
The plugs were the same color as the turbine wheel.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
BSOD2600
Post
by BSOD2600 » Mon Aug 11, 2008 5:07 am
BXSS wrote: I'd say the car is running lean.
Possibly caused when my car goes into fuel cut/starvation
during cornering ? Or that because the O2 is sluggish? I'm still getting ~23 mpg for 75% highway/25% city driving.
I've since installed a Walbro and haven't had a chance to test the low fuel + cornering issue.
'11 WRX Limited
'94 TW | R.I.P.
BXSS
Post
by BXSS » Mon Aug 11, 2008 1:28 pm
Slap a EGT/Pyrometer gauge on the car & see where your EGTs are.
Your mileage is very good for a SS - ? if the O2 sensor is giving the ECU a bad reading....
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
BXSS
Post
by BXSS » Wed Aug 20, 2008 3:33 pm
Here is a pic of the TD04 I took off my SS.
It is not as brown as I like to see, but was in the correct temp color ballpark.
http://bbs.legacycentral.org/viewtopic.php?t=35542
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
BSOD2600
Post
by BSOD2600 » Thu Aug 21, 2008 2:45 am
wow, those both are a lot darker/sootier than mine.
Don't have the cash atm to 'slap in EGT gauge', but I'll put it on the list. When I do get it, can I use the second bung hole in the DP, or should it be read in the UP?
'11 WRX Limited
'94 TW | R.I.P.
Post
by Legacy777 » Thu Aug 21, 2008 3:09 am
EGT temps really need to be read as close to the cylinder as possible. The stock exhaust manifold has a spot you can drill & tap for the EGT sensor. That would be a good spot for it.
BXSS
Post
by BXSS » Thu Aug 21, 2008 5:33 pm
+1 with the above.
I have the pyrometer probes (I have 2 of them - 1 per cyl head on my single port OBS-t) about 3" off the cyl heads.
The only place I could put a probe on the SS's 4-2-1 EL headers was right @ the point were everything merged to 1 on the up-pipe so I just add 100* to the temps on the gauge (everything is heat wrapped & I bet when the car is @ high RPM the gauge is on point but better safe than sorry).
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
RJ93SS
Posts: 853 Joined: Mon Jan 14, 2008 7:55 am
Post
by RJ93SS » Thu Sep 11, 2008 5:48 am
did my td04 swap and my vf11 looked like it was sandblasted it was so white!
BXSS
Post
by BXSS » Thu Sep 11, 2008 1:06 pm
Be careful - the TD04 flows a bit more CFM than the VF11 so thing could get whiter - closer to meltdown!
How do your spark plugs look?
Weird that the stock turbo is soooo white...
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
RJ93SS
Post
by RJ93SS » Thu Sep 11, 2008 5:23 pm
haven't checked the spark plugs in about 6 months, when i last changed them, but the old ones i pulled out were the proper brownish color.
my emissions were bad though, even after the new 02 sensor, i had to run through the test 3 times and the 3rd time i jacked up the tire pressure and took the air filter out
