Bolt pattern's size
metalhead77
Bolt pattern's size
Post by metalhead77 »
What is the bolt pattern's size for a 1994 Legacy LS? I'd like to know so I can determine what wheels I will be getting for my Legacy.
Spitfire999
Post by Spitfire999 »
5x100
You also need an offset of greater then +45 at the least. Standard subaru offset is in the +50 mm range.
metalhead77
Any suggestions on good, strong, name brand, and inexpensive wheels? I'm not expecting anything INSANELY cheap, but I don't want to be spending thousands upon thousands on a set of wheels. Thanks.
jamal
Vendor
Vendor
Post by jamal »
other stock subaru wheels are a good choice. 05+ sti stuff is about all that doesn't fit.
BAC5.2
Post by BAC5.2 »
jamal wrote:other stock subaru wheels are a good choice. 05+ sti stuff is about all that doesn't fit.
And SVX and Tribeca. They are all 5x114.
