I don't think he is doubting what you are capable of. He may be questioning what you think is involved in getting there though.
Is this in a Legacy? If so it is going to take A LOT of goods to get there. Just having a turbo capable of flowing that much air and a shortblock up to the task does not mean you'll get 450hp out of it.
What engine management are you going to use? I'll tell you right now, no piggyback will give you the control over a setup like that necessary to keep it together. My Link Plus G2 wasn't cheap. Either was the data acquisition needed to tune it.
What about fuel? I was able to talk Deatchwerks into making me some 900cc SR20 injectors. They don't suck fuel from the tank by themselves though. You'll be near the limits of a Walbro, and two of them is probably a good idea. The stock lines, series arrangement, and regulator are worthless to you at that point. The regulator to have is the Areomotive A1000. The line and fittings to make it work will cost more than the regulator itself. Outfront motorsports makes nice adapters for our rails to run some -6 to them.
Is this turbo internally gated? If not, a 44mm will be in order. I hope you can build your own pipe set, because people get insane money for a quality setup, custom or not.
Obviously a good clutch will be needed. Mine was $1200.
If you want to keep tossing in 5 speed after 5 speed go ahead. Or you can wait until you have something that can handle said abuse.
I hope to god that you'll have nice suspension and brakes to keep things under wraps. I don't mean WRX brakes either.
If you already have the 20G heads, by all means use them. Just don't expect to do well up high in the rev range. Hydraulic lash adjusters struggle to maintain valve lift up top. EJ25D heads, with maybe a conversion to shim-under or shimless buckets are a great option and can be had for cheap. They also have the biggest factory ports.
What I'm trying to get at here, is from my experience and the experience of several friends of mine, is take whatever you think your build is going to cost, and double it. That will get you in the ballpark. Seriously. Don't think that you'll get away with spending under $20k. I didn't.
