One more Question...
Locked
Brian White
Post by Brian White »
Another question for everyone. What spark plugs are
you running on your Legacy Turbo's? Going to be
buying new wires and plugs SOON so any feedback is
appreciated. Thanks.
-Brian
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Access Your PC from Anywhere - Full setup in 2 minutes - Free Download
http://us.click.yahoo.com/1GUySC/E6eDAA ... /XoTolB/TM
Josh Colombo
Post by Josh Colombo »
I run the standard NGK plug. I've tried almost everything out there. Bosch platinum's, the +4 platinum's, NGK has a weird 3 pronged one. The plain ol' NGK's work the best. I replace them probably a little sooner then the owner's manual states, but that's just me, and having peace of mind.
I know some of the other turbo owners have/are running iridium plugs, and also one zone cooler plug.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
of beats and rhythm" - ME
-----Original Message-----
Sent: Sunday, December 23, 2001 2:29 AM
To: Legacy Group
Subject: [BC-BFLegacyWorks] One more Question...
-Brian
Do You Yahoo!?
bussaca2@aol.com
Post by bussaca2@aol.com »
NGK's work the best. <<
Actually I've been on the Bosch Platnium +4 points since they came out, i haven't had any complaints and i thought they made a diferance over single point spark plugs...
dink, dink..
*dave drops in his 2 cents*
David Carter
Send FREE Holiday eCards from Yahoo! Greetings.
http://us.click.yahoo.com/IgTaHA/ZQdDAA ... /XoTolB/TM
Rod Grosvenor
Post by Rod Grosvenor »
Brian-I ran stock NGKs for awhile but am now running Denso Iridiums (both stock heat range + 1 range colder) to see which combo works the best. After my injectors are blueprinted, I`ll have the car tuned on a dyno to see which works better. I`ll post the results then. I have a Forced Air Tech turbo kit on my formerly NA `92 motor. See `ya---ROD AZ.)
----- Original Message -----
To: Legacy Group <mailto:BC-BFLegacyWorks@yahoogroups.com>
Sent: Sunday, December 23, 2001 1:28 AM
-Brian
Do You Yahoo!?
Locked
