A vacuum hose reference for EJ22Ts
Snorkus, filters, throttle bodies and intake manifolds.
mexicanzero
Post by mexicanzero »
oooooohhhhhhh the MBC goes in place of the boost control solenoid i get it now!!!!!! wow i feel so stupid THANK YOU!!@
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
yazmo
Re: A vacuum hose reference for EJ22Ts
Post by yazmo »
vrg3 wrote:I've been meaning to do this for a while... Today I drew up a diagram of EJ22T vacuum hoses:
http://www.graphics.cornell.edu/~v/vacuum/
I left off the IAC hose and the big BOV hoses since they're simple. I left off the PCV stuff since it's complicated. :)
Hopefully this will be useful for people doing swaps and/or replacing their hoses.
Please send me corrections if I got any of it wrong.
ahhhhhhhhhh
94SS_Canada
Post by 94SS_Canada »
Can we update this please, i really need this diagram
FastRust
I sent Vikash an email. It wasn't too long ago, maybe a few weeks about his Cornell site going down. More then likely the university took away access, which sucks. I don't know if he had everything backed up. I sure hope so.
My recommendation would be search on google, and see if you can access a cached page. Other option would be to use the internet archive to see if we can suck down those pages.
94SS_Canada
Alright, Back to google, ill post a link if i find something.
FastRust
scuzzy
Post by scuzzy »
#82 M4 TRSCCA Rallycross
94SS_Canada
PERFECT! Thanks!
FastRust
I worked yesterday sucking down what I could from the internet archive. I've got most of the first gen legacy stuff sucked down. Some of it wasn't d/l'd.
When I get it converted I'll host it on my server.
94SS_Canada
Perfect, Thanks for keeping the community alive guys, What is your server legacy777?
FastRust
http://www.main.experiencetherave.com
I haven't had a chance to add Vikash's stuff yet, but it will have its own folder under the subaru directory.
I think the server is down. It just says"Nothing to see here, contact the webmaster."
So I could just go to the auto parts store and buy the correct size hoses and cut them to length?
baddriver
Post by baddriver »
This is just what I need!
It appears that the link is broken. Is this information still available?
magicmike
Post by magicmike »
look up 7 posts from yours. Scuzzy is hosting it somewhere else.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
It's back up! Thanks, Josh, for hosting it.
http://www.surrealmirage.com/vrg3/vacuum/
You're welcome!
Added this to the new Intake forum sticky thread, so I will unsticky this thread unless anyone has any major issues with that.
darkcrave
Post by darkcrave »
Thanks!
Tune
TMIC
Fuel
Taillight
station2stattion
Post by station2stattion »
Oh man! THANK YOU SOOOO MUCH!
I am about to restore my engine bay and You even posted part numbers.. you are my HEROES!!!
ciper
Post by ciper »
Please consider updating the picture to note that hose J has a pill inside, part number 22326AA090 I think?
I used that diagram to replace my hoses and only found out accidentally that J was special. Luckily I had not thrown it away yet.
Are you sure J has a pill in it?
ciper
Post by ciper »
Yep absolutely certain. Keeps it from overboosting in fifth gear.
I am not 100% sure on the part number though.
Why, did you already throw away your pill?
I've been running a GM 3-port boost control solenoid since I put in my stand alone. I'll have to look at that hose and see if I can find the pill in it.
I guess without the pill you may have more boost exiting/venting back to the manifold vs. going to the wastegate solenoid. That makes sense. I think you could probably retune the BCS operation to not use the pill if you went with an aftermarket EBC, but that's probably not a big desire.
ciper
Post by ciper »
I'm thinking to replace my lower hose again, this time cutting the factory hose in half to get the pill out. If I do I'll try different drill bits until I find the right size and post it here in case anyone wants to make their own pill.
Yeah I don't know why they used such a big hose just to put a TINY restriction in it. Maybe the pill was an afterthought because it only really makes a difference in 4-5 while going uphill at lower rpm (in my experience)
It's possible you could use a smaller diameter hose with a step up adapter and small length of larger dia. hose to connect to the resonator box.
