Couldnt find anything in the search, What exhausts are a close fit for our cars, i like the Dual tip look of our stock exhasut, So How close will the axleback here fit?
http://forums.nasioc.com/forums/showthr ... ?t=1547931
Exhaust, Exhaust, Which WOrks
I don't think that a 3" axle-back will bolt right up, but I might be wrong.. If it was stock-size piping, then it should work fine. You could look for an STi axle-back. They run cheap and sound real nice on 2.2s.
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
You'll have to piece it together, there is no off-the-shelf solution for our cars. Any turbo header or stock headers fit. Up-pipes are interchangeable, just avoid later stockers with built-in cats. Most all downpipes will fit, but you'll have to relocate the hanger bracket on the pipe. 5 mins of welding. A cat-back for an Impreza is likely to come up short; you're better off buying a muffler to your taste, then take it to an exhaust shop and have them fabricate the pipes you need.
Personally, I used a Brullen with twin tips, rolled in and at an angle. 3" in, twin 1.5" out... looks sorta stock, to the casual eye, quiet at idle and around town, but it really barks when I cane it.
Jerry
CES is the only "off-the-shelf" exhaust that is "supposed" to fit. It's a nice exhaust, and performs well. I think its fitment, or better yet the manufacturing repeatability could be better.
FWIW- I ordered a cheapy WRX turbo back off of Ebay, $224 shipped to my door, and it 'fits'. Granted its a few inches short, hangs a little low because its not exactly in the stock exhuast channel and the hangers don't quite line up with stock, but I knew I'd have to mess with that stuff anyway. Regaurdless, it fits and works till I get it properly welded up.
04 Forester XTi VF39, TMIC, 3" exhaust, COBB accessport
92 Legacy L wagon 5 spd, 266K miles
83 wagon SOLD
04 STi COBB stage 2 & wingless SOLD
92 Legacy SS 5MT-TD04,TMIC, 3"exhaust SOLD
00 Legacy GT wagon 5spd SOLD
90 Legacy LSi wagon
83 wagon SOLD
90 Legacy LSi wagon
