Injector 30 degree pattern tip from Power Enterprise
yazmo
Post by yazmo »
yeah i am wondering cuz it's say work for
For the time being, these injectors are only for the EJ20 non-STi motor.
i read that 30 degree pattern help for the atomization and improve burn rate which mean that the same air/fuel misture can be achived with less total fuel flow?
they have RC engeineering also cheaper cuz those from power are very expensive.
is those fit on a legacy turbo 1994 ?
http://www.fastwrx.com/poenfuin.html
by the same time what swap are you recommend me EJ20 turbo 2.0?
They said EJ20 non-STi which would be the EJ205, meaning top-feed injectors and will not work in your side feed rails.
A bit easier and cheaper route is to find some '92-94 NA rails to use some SR20 injectors. SR20 injectors are plentiful and easy to come by.
Of course, some form of engine management or fuel controller is needed to actually use larger injectors and have the car run decently.
yazmo
Post by yazmo »
thx that was well respond
