Injector mods
Injector mods
Hi there! I was wondering if you could mod the stock legacy turbo injectors to flow MORE! I have read many wrx owners have done this and pushed there stock injectors over 600cc!!!
All they did was dremel the tips off them to do this!
Is this true? Can i do this to a 93 legy turbo.
Best Link:http://www.toronto-subaru-club.com/foru ... hp?t=81864
Thanks!
Thanks!
93 Legacy Turbo AT Sliver Stock, Ultra Rotty Body
93 Legacy Turbo MT Silver Rob Tune 550cc Lowered GT28 AWIC 4.11 05 Leg GT rims Mint body
95 Chevy Corvette MT ZR-1 Black X Brace Chipped
94 Legacy Turbo AT Blue Stock SOLD
06 Pontiac G6 AT Green Stock SOLD
no, not really.
Actually, you can.
But not the turbo pinks....
Take the 270cc RED injectors and grind/cut/whatever the flat tip with the tiny holes in them and presto, 500-550 injectors.
Just get them flowtested.
Doug....you need to chill on the post button.
Yeah you can't mod the stock turbo legacy injectors, which I said no.
You're going pay at least $35 per injector to have them flow bench tested. For $140 you are damn close to just purchasing stock '04-'06 STi Yellow 550cc injectors. I only paid $150 for mine from a local college student with high hp dreams.
Jason
I just posted in the Parts Shed a link to STi Yellow injectors on eBay that currently sit at $75 w/ no bids from a full car part-out.
Jason
these 270cc RED injectors come from what car?? Because if i can score some of them i could run a vf39! But..
would these 270cc moded injectors run on a stock leggy turbo computer???
If so COOL!
If so COOL!
The red injectors come from the 92-94 n/a legacies.
The ej25 injectors are top feed and won't work.
Ok, good to know.
Coool! now they dont run in the stock leggy turbo fuel rail, but will the computer beable to run them??
Yes i second these picture of the moded red injectors!
Does anyone know if these injectors run on the stock leggy turbo ecu???
They'll run on the stock ECU, but having some sort of piggy-back FMU is heavily suggested.
Jason
Depending on the actual modded flow rate, I can't imagine the factory ECU controlling all that extra fuel with any authority. That's got to be 35-40% additional fueling from what the ECU expects. Even if the fuel trims could compensate in CL, which they most likely can't, the OL fueling would be horrific. I wouldn't waste your time trying this.
Now if you were to through on a piggyback, then you would be just fine. The eManage would be able to do it as well as others.
1.) '02 WRX-2482cc-TD06H-20G-FMIC (just sold)
2.) '90 Legacy-2.5 turbo, VF39, Haltech E8 in-hand - waiting for the 5mt swap
The TurboXS Dtec fuel controller is rather inexpensive as far as options go.
Jason
Ok then. I need a seperate fuel management system. So then really this mod is all most useless... And seeing that i could get some sti injectors and run the same fuel management system and probably mod those injectors whats the point really!!
Thanks for all your help people!!
