With my lights on and blower on full blast, if I press on the brake pad (illuminating the brake lights), I notice a considerable drop in the RPMs of the fans.
Sometimes with my deck's volume turned up (the PO put in new speakers), if my headlights are on, and I turn the wipers up to high, the deck will turn off and then back on... until the wipers move again.
Most of the time when things like this happen, my Blitz turbo timer is reading somewhere below 10v, but I'm not sure where it's reading the voltage from.
The car doesn't have trouble firing... ever. But sometimes, very rarely, the starter solenoid will click and the engine won't turn over at all. I've only had this happen once in the last month and a half. I turned everything off and the car started just fine.
It seems pretty obvious what's wrong, but I'll let you guys make sure for me.
