Trans Trouble Codes
Buffman
Trans Trouble Codes
Post by Buffman »
Of course one is 24 the Duty C solenoid. Other two are VSS 1 and VSS 2.
Which one is the one in the dash? 1 or 2? Speedo worked correctly on it's drive back to the house. A little bouncy at times (barely), but functioned. Going to clear the codes and see if they come back.
Are their part numbers for these sensors for replacement?
VSS2 is in the dash.
