This is how it went
LSSS=13
LLLS=31
Thanks to legacy777's websites for this.
Code13 cam angle sensor No signal entered from cam angle sensor, but signal (corresponding to at least two rotations of cam) entered from crank angle sensor
Code31 Throttle sensor Abnormal voltage input entered from throttle sensor Sets throttle sensor's voltage output to a fixed value
What should i do about these?
This is obviously what my problem is with why my car wont start correct?
Just pulled these codes from my swap, What should i do?
I guess trace the cam sensor wire. Maybe replace the throttle sensor or maybe just needs to be setup properly. Let me give you a link to setup the throttle sensor.
TPS test:
http://www.surrealmirage.com/subaru/engine.html#tps
TPS test:
