I have a ton of parts and am parting out my legacy, selling my extra parts.
ej22t block $900
msd dis2 - new in box and programmable - $475
apexi safcII - SOLD
zeitronix wideband 02 with digital display - $300
blouch 18g - $800
06 tmic with cut samco hose and fittings - $120
legacy wagon headlights and tail lights $25 each
coil packs - $40
wrx brakes - front and rear calipers and rotors $200 for a full set
h6 upgraded rear caliper brakets and rotors - SOLD
ej22 power steering pump off of a 93 leggy wagon and a/c compressor
93 leggy wagon trailer hitch - $80
93 leggy wagon rear and front axles - $75 per pair
02 wrx wagon springs $70
02 wrx sedan springs $50
wrx rims with dunlop all seasons - $250
wbr fmic for 02 wrx - $700
ANY PART OFF of a 93 legacy wagon!!!
5mt with 3.90 ratio, male stubs, shifts perfect - $600
ej22 open deck block built with new ej22t pistons and ej25 dohc heads. $450 - bought a wrx before I sorted out the ecu so Im parting the wagon.
MAKE ME OFFERS!!!
FS - msd dis2, safcII, blouch 18g, 06 tmic, wrx brakes, ETC!
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Calipers ALL worked perfectly - have some pads I can throw in that have life left but dont expect them to handle any autoxing or anything...
I have rotors in varying shape... Some are clean, some have got surface rust. ALL are usable... I also have a set of front powerslot rotors with not so many miles.... take your pick and throw me an offer!!!
more info on the h6 upgraded rear caliper brakets and rotors.
i have herd of the upgrade but dont know anything about.
are they vented and larger? will they bolt up to NA or Turbo rotors?
may be interested.
-=Suberdave=-
www.suberdave.com
may be interested.
-=Suberdave=-
www.suberdave.com
they arent vented - they are about 1" in diameter larger than stock wrx rear brakes. Its enough of a change that I felt it when installed. They include brackets and rotors - they will not fit in turbo rotors, but they should bolt up to n/a... (if they dont, I can sell/include stock wrx rear calipers that will)
