Knock Sensor Replacement
1991legacyturbo
Post by 1991legacyturbo »
What are the procedures for replacing the knock sensor? i am also getting a code for a "can purge thing"???? how and where do i get one of those?
Buffman
Post by Buffman »
knock senor is pretty straightforward. Not sure if on the turbo models they are in the same location but on my N/A it's on the back of the block driver's side by the intake manifold. IIRC 12mm bolt holds it on :) Super easy.
ciper
Re: Knock Sensor Replacement
Post by ciper »
1991legacyturbo wrote:What are the procedures for replacing the knock sensor?
Unplug old sensor
Unbolt old sensor
*Optional - use sandpaper to clean mating surfaces
Bolt new sensor on
Plug senor in
Drive away.
altron23
Post by altron23 »
all subaru knock sensors are in the exact same place so far, super easy to do, easiest 1hr to get at work when flat rate!
-Garrett-
-subby tech-
eastside subaru
-90' legacy wagon L 2.2l 5mt swap, dumped on sti struts/springs
-88' RX-7 SE, waiting for some $ to be my track car!
1991legacyturbo
hey thanks guys. do i have to drain my coolant to do this?
kleinkid
drain coolant? NO.
Post by kleinkid »
The knock sensor has nothing to do with coolant. It simply bolts to a threaded, dead end, hole in the block. Make sure you are getting ready to remove the knock sensor and not the coolant temp sensor.
Buffman
Post by Buffman »
some engines have the knock sensors thread into the block into a coolant passage. it's that way on my LT1. Maybe he assumed that was the case.
1991legacyturbo
ok thanks guys. the reason i thought you had to drain the coolant was because my hanes manual said something about draining the system.
The purge cannister solenoid??? where do i find these and how hard are they to replace?
93Leg-c
Post by 93Leg-c »
When replacing the knock sensor, the fsm says to install the sensor with the wire going out at a 45* angle. This means if the passenger compartment is 12 o'clock and toward the radiator is 6 o'clock, the wiring coming out of the installed sensor should be at the 10:30 position.
I don't know the technicals as to why the fsm says that but here's what happened to me: I installed a new OEM knock sensor with the wire coming out at the 2:00 position because it was easier to connect the male and female plugs together. But my engine kept pinging and sometimes knocking. I read the fsm and followed the instructions for the 45* angle wire placement and the pinging and knocking went away.
'94 TW
Took me all of 2 minutes...maybe 1.
Bosco
Post by Bosco »
The cansiter purge solenoid is tricky to get to. if you know where it is, you can try to get at it.
I, along with a few others, have just left the bad one in place and plugged the 2 vacum lines and the wiring clip in to another sensor and found a place to put it. It can be a real pain to get to in it's stock location. (Under the intake runner behind the PS pump)
Replace it, and reset the ecu (possibly not necessary).
if you do a search, you will find a thread entitled "canister purge solenoid - fixing the problem" it has a nice picture of what it looks like if you're unsure.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
codfizzle
Post by codfizzle »
I was getting the same code, and you know what the problem was? My gas cap vent was plugged. It was building up too much back-pressure in the fuel system and throwing a code 35. As soon as I would take the gas cap off and release the pressure, the CEL would turn off.
