Note: I cleared this post with DLC first, so it has his blessing
I'll be the first one when I receive mine, but most people who are going with FMIC's are using WRX kits since the engines & exhaust are basically laid out the same w/o much modification. The side coming into the intake manifold would match up the same, but the side coming from the turbo would line up best on non-VF-11 turbo setups. Obviously it would be a total waste for anyone to install this on a VF-11, so that should not be a problem.93Leg-c wrote:Can you post pipe size and dimensions of IC, please?
Also, what kind of "massaging" needs to be done to make it fit a TW or ss? Any additional parts needed? or pipe bending, welding, etc.?
None on a Legacy yet, but see the above information. Most of the installs on this forum are using WRX FMIC kits unless they are home made (which some are & are done very well).n2x4 wrote:Any pics of it actually installed on a Legacy?
