CAN ANY BODY TELL ME IF THE 92-94 LEGACY TURBO COIL OVERS FROM
GROUND CONTROL WILL FIT MY 91 LEGACY TURBO ? AND WHAT IS THE
DIFFERENCE BETWEEN THEM? ALSO WHO MAKES UPRATED FUEL INJECTORS?
Monitoring Service trial
http://us.click.yahoo.com/ACHqaB/bQ8CAA ... /XoTolB/TM
COILOVERS
jason grahn
COILOVERS
a: caps lock; learn it, love it, then take it off.
b: yes they will fit, but if you want to make it easy you'll purchase the
entire assembly for the '92 and just put that in.
c: you probably don't need uprated fuel injectors unless you're running more
then 235hp. If you get bigger injectors, you'll also need a larger pump to
run them effeciently. Then of course, you'll need a bigger turbo to pump
enough air to match the fuel you have. But now that air is too hot, so
you'll need an intercooler. Then, since you'll be driving the stock ECU mad,
you'll need an programmable engine management system. Then, since you'll be
at much more then 235hp (hoping of course, that you already have a 3 inch
turbo-back exhaust), you'll blow up your transmission and you'll need to buy
a dog box from MRT.
total price = $a.lot USD.
-Jason Grahn
>From: "roo87114" <dean@swcp.com>
_________________________________________________________________
Send and receive Hotmail on your mobile device: http://mobile.msn.com
a dog box from MRT.
-Jason Grahn
Rod Grosvenor
COILOVERS
Try www.rceng.com for any info on injectors. Call & talk to a tech with your upgrade potentials so he can steer you in the right direction. I have B&G 11/2" lowering springs & KYB AGX struts + new strut mounts (STI in front-stock in rear as STIs did`nt fit there.) Firm but very responsive ride; I`d recommend this set-up to anyone that does`nt mind a stiff suspension. Good luck-ROD (AZ.)
----- Original Message -----
Sent: Tuesday, January 29, 2002 46 AM
Subject: [BC-BFLegacyWorks] COILOVERS
