good cruising PSI
joeWM
good cruising PSI
Post by joeWM »
so i just ordered my first MBC and gauge and i was wondering what is a good PSI to set it at, i was thinkin like 9 or 10, what do you guys think? only mods i got are TMIC, coffee cup, K&N cone air and exhaust.
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
BXSS
Post by BXSS »
You should be OK @ about 10psi - just listen for detonation, if you here any turn the boost back down to stock levels (8.7psi is stock)....
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
RJ93SS
Post by RJ93SS »
with a better intercooler and a hood scoop you could probably run it closer to 12, make sure to control your boost off intake pressure insted of turbo pressure
joeWM
Post by joeWM »
ok awesome thanks guys
BXSS
Post by BXSS »
+1 more boost = possible with better charge cooling, though I'd probably put a Walbro 255lph pump in the car past 10psi just to be safe as the stock pump is OLD.
What is done to the exhaust?
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
joeWM
Post by joeWM »
i got a 2.5" CBE with a silverline muffler with duel 2.5"outlets
Imprezive
Post by Imprezive »
on a stock turbo? You'll hit fuel-cut before you hurt anything. But keep it conservative, you can get a few more psi out of it.
I'm running ~10psi with a wrx intercooler and td05-16g with no detonation or anything, so you will be ok.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
asc_up
Post by asc_up »
You'll be fine at 10 PSI with those mods. I ran my car at 10 PSI stock for about 4 months.
However, to really take advantage of how fast the VF-11 can spool up, you might consider getting a 3" catless downpipe. I currently have a full 3" catless exhaust and that turbo is fully spooled by about 2700 RPMs.
92ss satinsvoice
Post by 92ss satinsvoice »
lol, damn. i was running a 16g at 15psi with stock injectors, stock pump. front mount and an exhaust. unfortunately it only lasted about 3-4 weeks. :lol:.
it was really fun though. i knew i was doing it all rong but just didnt care. i just wanted a reason to build the motor.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
