strange noise in reverse.....
92wagon
Post by 92wagon »
I have a 92 n/a auto wagon...I've had a strange squeaking noise in reverse for a while now....which is now starting to happen at slow forward speeds... does anyone know what this could be?...
Could be anything. My suggestion would be to put the car on four jack stands and put the car in gear and see if you can pin point where the noise is coming from.
94SS_Canada
Post by 94SS_Canada »
If i were you, just to be safe change your oils and you can rule out anything.
FastRust
