Intake Manifold Removal Questions
I plan on pulling the intake sometime this next week, so I can clean any gun inside of it out. Are there any tricks to the trade to remove the N/A manifold? I don't think any of the front drive accessories need to be removed, but is there anything that should be of concern when pulling the intake?
The vaccuum lines are likely old and hard, so plan to break a few. Other than that, It's pretty straight-forward a process.
old gas lines...either get a rag over them while twisting each line with a pair of pliers, careful not to damage the lines then simply pull on them or cut them and replace. also like stated above vacuum lines may easily break
Re: Intake Manifold Removal Questions
I wouldn't even waste my time. There probably isn't enough gunk in there to warrant the hassle of removing all that stuff, plus the intake plenum is pretty large anyway so I doubt it is causing any restriction.Buffman wrote:I plan on pulling the intake sometime this next week, so I can clean any gun inside of it out. Are there any tricks to the trade to remove the N/A manifold? I don't think any of the front drive accessories need to be removed, but is there anything that should be of concern when pulling the intake?
Saskatoon Subaru
