Chip for stock ECU!
Turbobeater has been working with them by providing his own car for use as a guinnea pig. In his last dyno session the following happened...
There are many of us that can spare a few extra dollars to help the Subaru Legacy community and Turbobeater has been putting forth his time, money, and efforts to do just that.TurboBeater wrote:Aaagh, well...good news and bad news...
I got 3 runs in, started off with the Stage 2 17 psi (peak) tune.
The first run didn't record because the dyno tach signal wire wasn't hooked up right.
2nd run was the good news, numbers were right on par with what we expected.
218 ft-lbs @ 3200rpm, 186 hp @ 5000 rpm.
3rd run was the bad news, seemed like major power loss. It really struggled getting redline and then when I let off the rpms dropped right past idle down to 0. At first we thought it could be a heat-soaked intercooler, but it wouldn't even start again, cranking sounded really funny. Checked the oil, it was 2.5L low!!After filling it up it starts now but sounds like I munched a main bearing. Idle is ok but a little rough. Rev to 3000rpm and it goes clank clank. No smoke out the exhaust and AFR was dead on 11.4-11.6 for the last run. When I drove it off the dyno it seemed completely gutless. Anyway, the 3rd run was 207 ft-lbs @ 3200 rpm, 159 hp @ 4500 rpm. Not bad considering it was seized enough to not start afterwards I guess.
Not sure what to do now, $5 of oil and I would be keeping up with stock WRX's right now. Should have checked it first, I'm an idiot. But I thought it was ok since the oil light should have come on right? Last time I checked the oil was a few months ago.
I propose that as many of us as possible send Turbobeater $10-$20 to help him fix his car so his efforts can continue.
So, if Turbobeater will sign on to this and provide a PayPal address along with an estimate of repairs we can get donating.
The few dollars you spend now to further this development will be saved later when you don't have to fork over $1200 for a Hydra EMS to tune your car.
