Where are the door lock/unlock and trunk release wires?
myth
Post by myth »
Vehicle is a Legacy L Sedan 2002 Auto
Subaru Legacy 2000~2002 wiring diagram
http://64.85.6.121/diagrams/diagram.asp ... nk=BULLDOG
It shows:
POWER LOCK WHITE (TYPE B) IN DRIVERS KICK PANEL, HARNESS FROM DOOR
POWER UNLOCK GREEN/RED (TYPE B) IN DRIVERS KICK PANEL, HARNESS FROM DOOR
TRUNK RELEASE LIGHT GREEN/YELLOW (5-WIRE) @ HATCH RELEASE SWITCH
A few other source on the web shows the same wiring info. So I assume the above is correct.
But I cannot find the above wires. For lock/unlock, I can see the harness from door but I cannot find them. For trunk, it seems that I need to disassemble the trunk release switch but I cannot disassemble it.
You might be better to ask that question in the Legacy forum on NASIOC http://forums.nasioc.com/forums or SLi http://www.sl-i.net/FORUM/
Most of the members on the bbs only have 1st gen legacies.
myth
Still finding trunk release wire.
Post by myth »
myth wrote:Vehicle is a Legacy L Sedan 2002 Auto
It shows:
I am installing a remote-starter; UltraStart G11t. I connected the other wires.
Power unlock info is not sufficient; there are 2 wires w/ the same color on the same harness. The wire on the same row as lock is not the unlock. Instead, the wire on the row 3 is the correct unlock. The problem is that the remote-starter unlocks all the doors at 1st push. OEM remote unlocks only driver door at 1st push and all doors at 2nd push.
I am still finding trunk release wire. I seems that I need to disassemble trunk release switch, but I cannot find a way.
