Bridgestone Blizzak WS-50 235/45-17 on 17x7.5" +53 Rota SDRs
(click images for gallery)
I was a bit concerned about the extra 10mm of width, and the extra height that would accompany it, but after a test drive with one tire on the front, I took the used set for a very fair price. So far they've been a very good tire in the cold, dry weather. We'll see how they go when the "real" winter arrives.
A tiny bit of rubbing when the wheels are turned and I'm going over driveways and with articulation, but otherwise not rubbing when driving straight. Plenty of strut clearance also, which is probably a result of the wheel offset.
