Viva el water trick!
flatoutfred
Post by flatoutfred »
To make a long story short, yesterday was my first leg turbo real test.
Snow has begin to fall over here and I know a few gravel roads that are accessible in the winter time. :twisted:
Rally time!!!
But after an hour of heavy beating (4000-6000 rpm), we decided to go elsewhere. While waiting at a stop sign, the engine start clicking like there was no freakin tomorrow, had a closer look and I figured it was coming from the valve train. On my way back, I could'nt feel any difference in power.
Today I've checked the oil the oil level and it was perfect. So I did a little search on my favourite scooby board and found a few topics about the water trick.
Hocus pocus, after following the instructions given by Ciper the car sounds now just like it did before, perfectly.
Thanks Legacycentral
I'm now looking forward to the next snow storm (it's raining right now :( but we had 15 feet of snow last year, so it's just a matter of days :twisted:).
Legacy turbo, desnorkled, intercooled, TD04, Borla catback, urethane mounts, wrx rear brakes.
BSOD2600
Post by BSOD2600 »
You want to link/further elaborate on this hocus pocus?
'11 WRX Limited
'94 TW | R.I.P.
flatoutfred
ciper wrote:Okay, this would be easier with two people. Ill give short instructions.
Drive the car around so its at stable operating temp (after fans come one)
Have a small cup of water handy and a container to fill the small cup back up
Disconnect the vacuum line from the purge valve. At idle this wont have any suction.
Place the line into the cup of water
As soon as you open the throttle plate it will start sucking. The water will cause the car to bog down, I kept it at about 4k rpm.
I had mine drink about 1/2 cup of water at a time. I then keep the RPM high but cover the vacuum with my finger.
You can tell when the water has left the intake as it takes less and less throttle to keep the RPM high. I kept the RPM at the high level for 10 seconds after it came back to normal/stable.
I let the car idle for about 30 seconds and inserted the tube to a refilled cup.
Repeat.
At first I was scared because my car sounded really weird. I took it for a 5 minute test drive (cruising and wot). After coming back and parking the engine noise was gone, I could clearly hear the ticking of the injectors now!
RJ93SS
Post by RJ93SS »
can you link it.
what was the problem and what did the water do
flatoutfred
tahiti350
Post by tahiti350 »
basically introducing water into the engine "steam cleans" the cylinders, valves, ports, etc. Carbon builds up on the surfaces, and sometimes will lift and cause a hot spot that acts as a separate ignition source, normaly causing pre-detonation or pinging.
The steam lifts the carbon deposits returning the engine to it's normal igition conditions.
Just don't over do it as too much water can take out the rings, and DO NOT let the engine die while water is being introduced. Restarting with water in the cylinder can cause hydrolock and bend parts....
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
BSOD2600
Post by BSOD2600 »
Sounds like a Seafoam treatment on the cheap...
'11 WRX Limited
'94 TW | R.I.P.
Post by SILINC3R »
so who wants to come to Georgia and give it a try on my car
Skruyd
Post by Skruyd »
SILINC3R wrote:so who wants to come to Georgia and give it a try on my car
You don't trust your self doing it?? Or would you just be happier if somebody came by?
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
Post by SILINC3R »
lol probably both
