I've separated the engine/ecu related stuff from the chassis harness, and bypassed the SMJ's. Yes, I'm going to do something with the power supply and yes, I need VSS etc... yadda yadda...
I'm using the 1992 FSM as a reference and working on a '94 turbo harness.
But, after the cutting and soldering, I'm stuck at the E2/F26 Connector. What do pins 7, 9 and 10 do?
Pin 7: Jurisdiction ID goes to c11 (B56.11) No prob.
Pin 9: ???
Pin 10???
One I belive is oil pressure, but the other? It would be nice to figure this out via bbs, instead of voltmeter and prodding around the manifold.
Thanks for the help! I'm trying to get ready for our local rally-x, and swapping my drive train into this old impreza L.
