I have a '94 Legacy wagon, auto, w/ 220+K on it. I had been getting intermittent CEL, codes 21, 32, 35. I replaced the canister purge solenoid, cleared the codes, and now I'm just getting an intermittent 21. The CEL light comes on for about 10-20 seconds while the temp gauge is in mid-travel between cold and operating temp, then goes out and stays out. Temp gauge on the dash appears to be functioning normally. Does this sound like a "typical" sensor failure or might there be something else at work here? Anything I should be aware of if I need to replace this?
Thanks.
water temp sensor
The gauge on the dash and the ECU use two different temp sensors.
How does the car run when cold?
The sensors are pretty cheap, around $20, so I'd suggest replacing it.
Tim Catton
codfizzle
I just replaced the coolant temp sensor on mine, also. I was surprised to discover that a 3/4" deep socket fit even more snugly on the sensor than any metric size. Also I had to temporarily disconnect the PCV hose so I could get at the sensor at the proper angle. Easy job, though.
92 LEGACY EJ22 WAGON
Tim Catton
codfizzle
I just plugged the hole with my finger as I pulled the old one out and put the new one in. Probably only lost 5 drops of coolant. It's completely unneccesary to actually drain any coolant out, as the manuals usually say to do. And make sure the socket you use is a deep one, so it can fit over the electrical connector. And a 6" or 8" extension helps a lot. But, seriously, I changed mine in 5 minutes while on a cigarette break at work. Easy peasy lemon squeezy.
Tim Catton
codfizzle
Actually I was having a totally different problem, but I initially thought the coolant temp sensor was the culprit, so I changed it. It turned out to be something else, but I'm glad I changed the sensor anyway because when I took mine out, it fell apart in my hand; the plastic part where the electrical connector connects to it just fell off of the metal part. It was really corroded, but it never did throw a CEL. But changing it fixed a couple of little electrical quirks I was questioning previously, so it helped there too.
