you should be a director with that footage.
sound is great, although your engine don't sound to great
Hard starting
I would look at trying a new MAF sensor, as well as inspecting the wire for the coolant sensor, hopefully you replaced the ECU temp sensor and not the guage one. Do you give it throttle on startup at all?
there's two sensors back there. Single wire is for the gauge, and the double wire is for the ECM.
Mine did something weird today. Wife started car, fired right up, then realized she used her key not mine. She turned it off, and went to restart it, and it wouldn't restart. I come out and it cranks and tries to start. I open the gas pedal a few times, and it fires back up. Started fine so far today. Not sure why it did that, unless maybe IAC had a brain fart.
