VF11 housing
LegacyT
VF11 housing
Don 't know specifics about these turbos. But is it possible to rotate the outlet housing so that its 90 degrees, like a tdo4/05?
Yes I believe you can rotate the housing. Are you wanting to rotate the exhaust or compressor housing?
the inlet pipe on it wont work if you turn it, but it can turn. the 90deg elbow comes off (2bolts) but your going to have to fab up something to make it stay on.
