sti fuel pump????
sti fuel pump????
OK, so I'm going to be swapping an EJ22T into my 94 impreza L. I'm pretty sure the stock fuel pump won't be enough. But a stock sti fuel pump should be adequate for a lightly modded EJ22T, right? Also, does any turbo subaru downpipe fit?
SLODRIVE
Yes, an STi pump will be more than plenty, that's what I'm going to use.
I think WRX/STi downpipes fit with no problems, I'm sure someone else can chime in on this...
http://www.slodriveracing.com
-And more!
-And more!
WRX/STI dp will work dandy but why spend $125 which everyone seems to think they should charge for them and spend $150 for a Ebay 3in bellmouth dp. Also as he said the STI pump will be plenty but depending on how much your paying you might as well get a brand new walbro 255 fuel pump for about $100 shipped. Just throwing it out there.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
I agree with both of those statements.adema2626 wrote:WRX/STI dp will work dandy but why spend $125 which everyone seems to think they should charge for them and spend $150 for a Ebay 3in bellmouth dp. Also as he said the STI pump will be plenty but depending on how much your paying you might as well get a brand new walbro 255 fuel pump for about $100 shipped. Just throwing it out there.
And if you have the EJ22T fuel pump (and it's in good working order) use that over the STi fuel pump. It flows more.
94SS_Canada
Our Stock ones flow better than the STI ones? no way....asc_up wrote:I agree with both of those statements.adema2626 wrote:WRX/STI dp will work dandy but why spend $125 which everyone seems to think they should charge for them and spend $150 for a Ebay 3in bellmouth dp. Also as he said the STI pump will be plenty but depending on how much your paying you might as well get a brand new walbro 255 fuel pump for about $100 shipped. Just throwing it out there.
FastRust
Rumor is that the the stock EJ22T fuel pump is better than the early USDM WRX, but not the STI....although none of them is in the Walbro league.94SS_Canada wrote: Our Stock ones flow better than the STI ones? no way....
Here are some examples of Subie FPs : From HERE
What are the OEM fuel pump sizes?
2002-2005 WRX fuel pump 130 lph
2006-2007 WRX fuel pump 145 lph
2008 WRX fuel pump 155 lph
2004-2007 STi fuel pump 145 lph
2008 STi fuel pump 175 lph
EJ22T fuel pump ~135 lph
list of top feed injector sizes for the 2002-2008 WRX and 2007-2008 STI:
OEM 2002-2005 WRX 420 cc
OEm 2004-2006 STi 535cc
JDM STi "pinks" 550 cc
OEM 2006-2008 WRX 560 cc
OEM 2007-2008 STI 560 cc
EJ22T - 370 cc
Plus an STI FP is cheap on NASIOC...but you'll want the install kit:
Walbro fuel pump install/conv kit: 400-791 (I made it work w/my STI pump, too)
Walbro pump: GSS341
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
+1!adema2626 wrote:WRX/STI dp will work dandy but why spend $125 which everyone seems to think they should charge for them and spend $150 for a Ebay 3in bellmouth dp. Also as he said the STI pump will be plenty but depending on how much your paying you might as well get a brand new walbro 255 fuel pump for about $100 shipped. Just throwing it out there.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
i just bought the walbro 255 and i need to change it out.
does it matter if i have a full tank of gas in my car or should i wait until i have less in there?
and recommendations on the installation?
thanks,
thanks,
