I will look up the wire sizes and colors on a wiring diagram, then see if I can find the ignition relay plug in my spare wiring harness. I'll report back. Let me know if this is an emergency.
Bill Robinson
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1818248.33 ... 847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =243727101>
Ignition Relay Location
Ignition Relay location
The earlier post about the ignition relay location appears to be correct. I found it on my spare wiring harness. It is no farther than 18" from the fuse box and is definitely on the passenger side of the firewall. It is the center unit in a gold steel bracket that holds three relays. It is square, butterscotch brown. It branches off from the fattest part of the wiring harness. It has two enormous yellow/red wires and two enormous plain yellow wires, plus a couple of other thin wires.
When you find it, tell us exactly where it is and how to get to it.
Bill Robinson
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=215002 ... =845771407>
Bill Robinson
ADVERTISEMENT
Had my dash out today...
Ignition Relay is on the drivers side firewall up high, near the windshield, there is a brown relay with 6 wires into it and a round silver relay with 4 wires. There is also the fuel pump relay there also with 4 wires. The fuel pump relay, one of the ignition relays and a fan relay on the pasenger side are all the same relay part numbers. The big ignition relay is brown, square. These are the relays mentioned below.
Mark
-----Original Message-----
From: William D. Robinson [mailto:vultureboy@mindspring.com]
Sent: Friday, March 22, 2002 9:22 AM
Subject: [BC-BFLegacyWorks] RE: Ignition Relay location
Bill Robinson
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=215002 ... =914985907>
Mark
Bill Robinson
ADVERTISEMENT
