Timing belt kit
94TurboWagon
Timing belt kit
Post by 94TurboWagon »
Will this kit fit the EJ22T
ebay link
95 Svx 75k miles
98 Outback Limited 142k miles
06 LL BEAN 115k miles
PhyrraM
Post by PhyrraM »
The belt and idlers will, the water pump will not.
94TurboWagon
Thanks, all I need are the idlers, I have oem belt and pump already. $75 for pump and $45 for belt from my local subaru dealer. I buy lots of parts there, so hence the good price.
95 Svx 75k miles
Before you buy that kit, look for a different one almost exactly the same without the pump. I bought the same kit off ebay a couple months ago without the pump. Why waste money on a pump you won't need?
n2x4
Post by n2x4 »
kimokalihi wrote:Before you buy that kit, look for a different one almost exactly the same without the pump. I bought the same kit off ebay a couple months ago without the pump. Why waste money on a pump you won't need?
+1 I got the same kit without the pump for $70
SUBARUEHS Racing
253.Asmo
Post by 253.Asmo »
Looking to replace all my timing belt idlers/tensioner. How are the quality if these kits? My oem belt only has about 15k on it, so that shouldn't be a concern.
Opinions or suggestions please. Thanks!
Matt
n2x4
Post by n2x4 »
I thought the bolts that come with the kit were junk but everything else seems fine. No experience with the kit other than installing it. We'll see how it goes after I put some miles on it.
SUBARUEHS Racing
jp233
Post by jp233 »
I thought the same thing. The bolts look chintzy, I'll be re-using the stock bolts, but the bearings appear good. http://www.gmb.net/
The do list ISO 9002 on there, which is a good thing, however I don't see their listing right away.
Anyways, it looks like a N.A. company that once again outsources the manufacturing to China, and imports everything through Carson, Calif. This is nothing new,,,, there's about a zillion companies that do the same thing.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
253.Asmo
Post by 253.Asmo »
thanks for the info guys. looks decent enough for my application (tdo4 tmic etc) so i'll give it a shot, leaving out the bolts and using my oe belt (has about 15k) so i'll post another opinion in 6 months or so :)
matt
1-3-2-4
Post by 1-3-2-4 »
that ebay link is slowing slow as piss.. anyways I will add my two cents..
I brought a ebay kit. (timing belt, water pump and all the gaskets and idliers)
anyways I installed all but the cam seals and I've had no issues at all.. the idlers were from GMB and I used the bolts that came from it..
the seller on ebay was domestic gaskets.
dont use the paper water pump gasket get the Subaru OEM gasket.
I bought this one
ebay link
Belt was not OEM but it seemed fine to me, was made in thailand I think. The idlers and all were great to. Just don't use the bolts included in the kit. You can use the one for the tensioner, but not the others.
