where to buy new td05-16g turbo with 90 inlet
chochocho
Post by chochocho »
where can i get a new one?
BXSS
Post by BXSS »
I was gonna say deadbolt, but a buddy of mine had a 18G clipped & rebalanced CHEAP @ a some place, I'll get the info from him.
I bet they could do a nice rebuild on the cheap or may have a rebuild kit - even cheaper!
I just got a 17B compressor housing/wheel that I was thinking about slapping onto an on 14b center section for a cheap medium sized turbo.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
RJ93SS
Post by RJ93SS »
i wanna know too
BXSS
Post by BXSS »
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
chochocho
Post by chochocho »
where's a good place to mail for a full rebuild?
BXSS
Post by BXSS »
My friend has dealt with a few of the bigger turbo places for clipping/porting rebuilds & actually likes this place very good quality & prices.
Looking @ the 18G he just had clipped & balanced by the above place they did an excellent job...
The compressor housing I got was actually a TD06 17C (not a 17b) off a Typhoon/Cyclone, I plan on having these guys make me a TD06/TD05 hybird turbo with a old 14b I have laying around. Its not really an upgrade from a 16G, as it flows just 550CFM but it is a decent step up from a TD05-14b which flows just 405cfm.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
BXSS
Post by BXSS »
chochocho wrote:where's a good place to mail for a full rebuild?
Do you want a kit with instuctions or do you want to send your turbo away?
Did you see the link I put up?
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
chochocho
Post by chochocho »
thanks. let me check it out.
BXSS
Post by BXSS »
They have 16G to 18G compressor upgrades for about $225....
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
chochocho
Post by chochocho »
rebuild getting expensive :)
BXSS
Post by BXSS »
Well if you are already in there you may as well upgrade!
Still much cheaper than a new 16G.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
BXSS
Post by BXSS »
Found out the TD06-17C Typhoon/Cyclone compressor I have was upgraded to either TD06-18G (585cfm @ 1 bar) or TD06-20G (650CFM @ 1 bar) trim.
So this little hybird should be a nice upgrade to a TD05-16G once I get the work done to make the TD05-14b into a TD06/TD05 Hybird.
Here is some turbo info.
http://www.mitsubishiforum.com/m_61426/tm.htm
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
yazmo
turbo
Post by yazmo »
hi guys just wonder if any TD05-16g work.
as exemple its write TD05-16g for Mitsubishi Eclipse or LANCER EVO ALL 4G63T TD05 16G TURBO
do i have to look for subaru wrx TD05 16G?
any year particuliary?
just wanna know what exactly i should look for
thx in advance
here something i find relatiely cheap just wonder if this work!
http://quebec.kijiji.ca/c-autos-et-vehi ... Z114532825
yazmo
Post by yazmo »
if this work guy
n2x4
Post by n2x4 »
That will bolt up, as it has the Subaru specific exhaust flanges (in from uppipe, out to downpipe).
You'll need to come up with something for the inlet (weld on a 90* aluminum piece or get a 90* silicone elbow)
SUBARUEHS Racing
yazmo
Post by yazmo »
is 300 hundred is a good price?
CFK
Re: where to buy new td05-16g turbo with 90 inlet
Post by CFK »
Ya,Old thread I know, but my 16G Just Sh!t the bed and im having trouble finding one with the 90
Anybody know ?
Thanks :!:
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
They are rebuildable, and can accept the updated (ie. lower resistance/faster spooling bearing cartridge). I had been talking to these guys here: http://6starspeed.com/, but I'm sure there are other (and possibly cheaper!) businesses that'll do it as well.
CFK
Post by CFK »
ya I knew there rebuildable, but I kinna wanted the most out of a new TD05 since it's easier and cheaper than upgrading to a VF39/550/Re-chipped RobTune.
All iv'e seen is blouch and a few others, but there all the straight in type. So I figured I might as well upgrade if its blown.
Then again a faster spool alone would be a great upgrade alone since im fairly happy with the power. But lets be honest, we could always use a few extra HP ! :-D
Build Thread : HERE
Yeah I've been contemplating having mine (a 90* inlet also) rebuilt with bigger wheels, and a twinscroll housing. I really need to get my RS swapped before I can spend money on the SS though. :(
CFK
Post by CFK »
Ya it minna looks like the only option as I can't find any aftermarket companies that make a P&P unit with a 90.
I'm waiting for an email back from Blouch, and if they don't sell any which I assume they don't . I'll get a quote on having mine rebuilt and beefed up.
I'm just not sure what the best combo for me would be since I'm running SOHC, an 8cm turbine might be to big and spool way to slow, but I have no idea ?
Build Thread : HERE
CFK
Post by CFK »
Sounds like I'm SOL unless I wanna purchase a new one and pray a short radius 90 would fit.
I spoke with Blouch and they said only a factory rebuild was possible with them and no upgrades can be made. Only an 8cm exhaust housing, but nothing to the compressor side.
On my old TD04 I had an aluminum 90 trimmed up and welded on, but it was extremely tight and that was on a smaller housing. Not sure if that would work on a larger TD05 ?
So I'm not sure what I'm gonna do, I'll have to pull the turbo and find out what the damage is. Cause if there's anything wrong with the cartridge it would probably be $800 to fix. Which is the cost of a brand new Kinugawa TD05 (Big, 8cm. $650) and pretty close to a Blouch TD05-16G (small, 7cm $1000)
Build Thread : HERE
