New guy,new project.
gijonas
Post by gijonas »
Hey all,been lurking a while and decided to post up my project.I have recently acquired the turbo legacy that my late best friend owned and i plan to make the car into what he would have wanted,and a little of what i want :-D
The car is a 94 5 speed and is in great shape,i also have a parts car to go along with it that i got yesterday.The original motor got seized so i ripped it out and will be putting the good donor in soon.Im an accomplished mechanic so all this work will be done in my shop by myself.
Near future plans are already in progress: Tdo4 off a WRX,pretty much new turbo :P , custom setup air to water intercooler, rising rate fuel pressure regulator, walbro fuel pump, WRX clutch and flywheel,custom up and downpipe as well as some essentials such as wideband, boost gauge and such things.My plan is to run the car at max potential on the stock ecu safely,then move onto standalone after getting the big stuff sorted out and start working on big numbers :-D ,suggestions or comments welcome,thanks.
P.S. mods move this if needed.
RJ93SS
Post by RJ93SS »
welcome to the board, sounds like a fun project.
fyi
there's actually a build section in the bbs so you will be able to post your pic's and progress there.
also, revtronix now has a chip for our cpu's that might interest you.
check it out
good luck with your build
gijonas
Post by gijonas »
thanks,looked into that.Unfortunately the stage two seems to still be in development.Oh well guess i just have to go standalone :-D
