What is my compression ratio with .020 overbore Wiseco pistons in a Ej22 block with EJ20G heads?
The heads came off a 1989 JDM Legacy. I'm pretty sure they are the ones with the 57 CC combustion chambers.
This chart:
http://www.nolimitmotorsport.com/wiseco ... ubaru.html
Says the piston dish is -20CC and I also saw that on the box when I installed them. It says that I get 8.5:1 compression with a 46 CC head. If you add 10 CC to that what does the compression ratio come to?
Ej22 /w Ej20G heads and Wiseco pistons - compression ratio?
please be carefull!! i gave one to a friend and i guess that was all he ate and he almost did the chicken
'92 TW "Hana" ej20tt obd1 <too many to list< sold
bought back
